Can somebody tell me wat the inlet en wat the outlet is of the two heaterpipes on the rear of the waterpomp? I am afraid that i put them on the wrong way!
Regards Sjorz
heaterconnections
Im pretty sure they are both inlets aren't they. Thats how i got mine wired up anyway. There is an outlet from the back of the manifold to the heater, then from the heater to one of those hoses in the back of the pump. There is also a thermostat bypass on the front of the manifold (or there should be. It may be on the thermostat housing if you got the righ one) that attaches to the other inlet in the back of the pump. I have an offy manifold. dont know what yours is, but im pretty sure that's it. they are both inlets.
