Have tried searching but can't find any with the same set up as me, I'm using an Offy 360 manifold with a small outlet on the rear, on the front there is the stat and a tiny little pipe built into the stat housing (???). It is an interim front cover so only has 1 big water pipe on the pump, no smaller inlet/outlets for ancilleries.
How do I plumb the heater matrix in?
I think I'm going to put a swirl pot in between the manifold and top rad hose, like some TVR's, then I will get a filler and expansion bottle in the system, the rad has no filler and is slightly lower than the engine water outlet.
Another heater plumbing question
- topcatcustom
- topcatcustom
- topcatcustom
