ok i know it sounds weird.
would it be easy enough to convert my rear strut suspention to run leaf springs instead????????
just a thought i have had kicking around for a while and was wondering if it was possible on a mercedes 190e???
strut to leaf spring question
- topcatcustom
- topcatcustom
Probably far less effort to buy a leafsprung car and fix it up really nicely to your spec than to mod a car that has been designed for multilink suspenders.
It goes far beyond the fitting of mounts and beefing up around the mount areas. These cars have load paths designed into the body to accommodate the multilink and you may well compromise the structural integrity of the vehicle by changing those paths to redirect spring forces into different areas.
My tuppence, FWIW.
My tuppence, FWIW.
