Jag IRS mods again
Jag IRS mods again
Is it feasable to convert from inboard to outboard discs?
I own two cars both of which used Salibury Jag based IRS's that I'd dearly love to get that 4-wheel dusc brake look from the Italian exotics?
An alternative I'd thought of was substituting for an XJ40 Jag axle but maybe this is biting off more than one could chew???
Thoughts?
Thanks.
Phil
Thoughts?
Thanks.
Phil
- topcatcustom
the hardest part would be finding a way to mount the callipers to the floating hub, the obvious way I would be looking at is finding somebody who makes steel hub carriers, I have seen them, I would think the KitCar world would be the place to look,
If you have a friendly welder, they MA be able to weld brackets to the alloy hubs, But the area needed to welds to is not that thick. and may well pull the hub out of shape.
Wiki has the answer !
http://en.wikipedia.org/wiki/File:1995_ ... bframe.jpg
Looks like the later xjs had a "crossover" unit, the later ones look much diffrent
So thats where it went !
Thanks for all the feedback.
Something I've learned is that the late XJS 6.0's had the X300 vented discs and better calipers, Brembo's I believe.
In fact I have some of these calipers so they may finally come in handy.
The only problems, and I think they're pretty minor is that I'll need a spacer to mimic the in-bopard discs that will be removed and I've been told the lower fulcrum pin holeswill require some packing pieces.
Will have to sort out a handbrake mechanism. Something hydraulic would be far far superior to the crap Jag handbrake.
I'll let you know how I get on.
Phil
Phil
- topcatcustom
Hydraulic handbrakes are officially allowed, but they have to be completley seperate from the main brake system (even different fluid resevior) and fail safe also they have to demonstrate that they wont creap off. The net result is most MOT places will not pass them no matter what, and SVA likewise.
Citroen have had them on some of their cars on and off over the years, their way around it was to have a mechanical (big spring and friction "servo" on the brake shoe) that held the handbrake on until the Hydraulic system disengaged the break when you had hydraulic pressure and released the handbrake leaver (which was actually just a hydraulic valve). Fairly obviously if you lost hydraulic pressure your brakes came on, but on the relevent models if you lost pressure you lost everything so you wanted the brakes to come on
- topcatcustom
Guys,
Thanks for all your thoughts and feedback.
I mentioned a hydraulic handbrake earlier as I was sure I had read somewhere where a second and smaller caliper was used as the handbrake.
As I am intending to go to the hassle of converting from in-board to out-board rear discs I though what better time to try and improve on the Jag style rear 'penny washer pad size' handrake.
If I can replace the in-board discs with ali spacers then I'll also be saving a considerable weight.
I have just purchase at £50 a pop two X300 Jag rear hubs & drivershafts with vented discs + calipers - nice.
The first TVR wedge with outboard discs
Phil
Phil
I just came across this rear handbrake and wonder what all your thoughts were about such a unit?
http://www.ultima-gtr.org.uk/photo.php?pic_id=67
This is on an Ultima but this same Brembo cable operated handbrake caliper is offered by Gardner Douglas for under £200.00.
Seems cheap for a new, complete and legal handbrake - looks nice also!
Phil
Phil
