Thanks for the reply. Yeah I am pretty good technically and build wise. All I need is to get my hands on a pirate copy of Abaqus so I can do some FEA on the parts! Or when my PhD starts, use the college computers. the main problem will be fabricating the brackets to mount the calipers and the bell to mount the discs and fitting it to the axlekiwicar wrote:If you are going all disc then it should be possable, I am assuming you are of reasonably "robust" build to be contemplating this . You will need large discs 315 front 280 back minimum if you run 2wd, 315 all round for perminant 4Wd, to make the most of your pedal effort and probably 4pot calipers all round, but carfully worked out then it should be do-able.
best regards
I've spoke to AP racin gand they have suggested front and rear calipers for me. 4 pots. Also he said it would be best to use disc smaller than the 320mm which are meant for the calipers due to me having 16 inch wheels.
