Shaved door handles - safety issue?
Hi all,
Ok, so this year I want to start drag racing my astro van.
One issue I have is that the door handles have been removed and the door smoothed over. Doors are opened electronically by a solenoid that pops the latch (button on outside although hidden)
Im probably about to answer my own question, but is this going to be a safety concern?, Likely to get turned away at the track?
If it is ill have to start making changes quick sharp.
cheers!!
Stu
cheers!!
Stu
Re: Shaved door handles - safety issue?
I'd get cracking if I were you.Stuball wrote:If it is ill have to start making changes quick sharp.
cheers!!
Stu
I can't see the scrutineers letting that one slip past.
Wouldn't entertain it theese days unless it was on lowrider stu ! have a look how lawrence did the vauxhall ones on his truck it might help ?
www.project55.co.uk
www.project55.co.uk
So thats where it went !
Having just had an MOT failure on a broken rear door mechanism (and had to do without the car for a week while it was fixed) on the MOT jargon version of car "cannot be accessed from outside by door handle", or words to that effect I am suprised that you chaps are getting through the MOT let alone passed scrutineering. I appreciate the TVR is a special case and will have been type aproved like that but so it is difficult to fail it now but I still do not see how it can pass and mine fail
Regards MOT, although it doesnt have handles, both front doors on my van can still be opened from outside and inside using "the relevant control" (quote from the MOT manual), which is why it passes. Probably how TVR get round it too.
Never raced the van before which is why i brought it up. Ah well, on with the modifications
Stu
Stu
You certainly wont get turned away from Santapod Stu...
I doubt North Weald and York will be concerned either..
Santapod do not scrutineer any vehicles for RWYB.
The other two sites only check for secure batteries, wheel nuts all in place, dual throittle return springs and seat belts etc..
At Santapod all you need to do to run is NOT be dripping fluids on the start line and not be driving a vehicle that looks obviously like it should not be driven at all because it looks like a wreck.
If you were running the vehicle in a specific race class at any track then there would be guidelines that you would need to adhere to.
But for RWYB there really arent any vehicle spec rules. Dont waste your time altering what you have just for a few race days mate. You wont get turned away from anywhere for RWYB
Perry
Perry
