The mx5 Rv8,.. thing!
- topcatcustom
Well..... the engine and gearbox went in on sunday
Got to lift them out, weld up the mounts, then should go back in for good with any luck- then its fitting the brake pipes, fuel line, water pipes and all the electrickery I enjoy basic wiring but not sure how I'm going to do the speedo yet- it might be a case of pulling the existing console out and making a new one to take old smiths gauges, the only reason I'm not over keen is I dont want to fit el cheap cheapo ones but new gauges aren't cheap!!!
TC
Looking good TC. How many gauges do you plan on using?? rich
- topcatcustom
Was tempted to go with as many as I can fit in but decided against it now! Will be speedo, rev counter, water temp, oil pressure and boost, maybe voltage too. Dont think I'll worry about oil temp etc as I'm not intending on stressing the engine for every bhp anyway! Just want some fun and not worrying any more that I already am about melting the pistons
TC
have alook on the real steel site, forget melting pistons, more like melting rear tyres
- topcatcustom
I've been wondering how this was going, looks good and you've done some work on the bay as well.
I've used the SD1 speedo cable it actually fits on okay, I seem to remember I had to take a sleeve off, but it slid on and works fine. I'm using a speedometer from a 1.8 because that shows up to 140mph, the original only went up to 110mph. Checking against the sat-nav it's quite accurate as well.
Careful how you take the cowl off, the plastic lugs break easily, you have to pull it straight towards you, gently.
Andy
Andy
- topcatcustom
Hi Tom
the charge cooler can be connected to a radiator like an oil cooler matrix and an eletric pump. The matix below super charger probably only needs to be about 1.5" thick, again it could be another oil cooler matrix.
Anyway if it put the top of the supercharger above the roof line it would look dead cool
- topcatcustom
A few more pics-
my reason for the dilema on how to get my o/s exhaust out of the damn engine bay!
...and from underneath- very limited room for exhaust between clutch slave cylinder and starter
So a bit of chopping...
And a bit more chopping and welding gives me a good 15mm more room all round
So hopefully when I put the lump back in this week I will be pleasantly suprised at just how much room for the exhaust manifolds there is
TC
- topcatcustom
- topcatcustom
