Uncobra, the V8 FrankenHealey
kev_the_mole
Post by kev_the_mole »
Now I've got the bug perhaps the estimable Mr. Cooper could arrange a V8 Forum Track Day and we could all see each other's cars performing (but only after I've fixed mine! :D )
I think it's pretty brave to take a new car on the track without some testing first!
Everything I've done has had some wrinkles to iron out. Even the big manufacturers make a whole batch of cars to sort out the wrinkles!
kev_the_mole
We tried it round the industrial estate first (not on the road, honest guv'nor).
....but I did wonder why none of the others there that day wanted to give it a gentle run :lol: :lol: :lol:
kev_the_mole
Wooo Hooo
passed its MOT yesterday with flying colours including the slightly suspect, devious electronic line-lock 'parking brake' :D :D :D
....then it boiled over coming back from the test centre so maybe the problem wasn't lack of an expansion tank :cry: :cry: :cry:
Is God telling me something???
kev_the_mole
Sitting in traffic or just leaving the car idling in the drive while opening the garage door and the temperature shoots up. The poor little 14" fan struggles to cope when the air temperature goes over 18C.
Weeny fan
This shouldn't happen with a Serck Motorsport radiator but I did compromise the design by insisting on keeping the bonnet hinges and that made the radiator smaller than first anticipated.
Short radiator due to retaining bonnet hinges
Another cooling problem was that after a few circuits on a trackday the car would be dumping water and it looked like we had a recurring air lock. Because the radiator was relatively low it meant the top hose was higher than the radiator filler. To cure this problem I fitted a Moroso top hose filler neck and fingers crossed it looks like the air lock has disappeared. I also decided to use a Stant radiator cap with a flip over valve to release the pressure safely if I get further problems.
In the spring the radiator comes out to have its filler neck modified and I'll tidy up the hoses then. Also I'll add another 14" fan so they run side-by-side and should provide enough low speed and warm weather cooling.
kev_the_mole
I was off to Salisbury the other weekend for a pastie lunch at Pete Farmer's and to look over the cars in his workshop when the SBC started to miss occasionally. A few miles down the road it deteriorated to a 5/6 cylinder, popping and banging, no tickover and stalling at junctions. I turned round and headed for home and at about two miles to go everything reverted to normal. It was obvious from the exhausts that it had been wildly over-fuelling. So what was wrong?
The electrics and the MSD checked out OK. Fuel pressure was 6psi which is OK for Holleys so it had to be the carb. The car runs a double pumper which gives great acceleration but is eventful driving at 30mph. During the rebuild I was asked if I wanted to keep the "POS" and this led me to thinking about new carbs. Didn't want another Holley, Edelbrock's didn't appeal and Demon's can be a lot of money.
Then I had my :idea: moment.
I had nearly all the kit to convert to Megasquirt because I was collecting the kit to convert my son's 6-cylinder. :D :D :D
Santa had brought me one of these
with a few other bits
ordered one of these
So now all I've got to do is bolt it all together, learn some electrics, learn some electronics and computery stuff and this is all after I promised myself that the car would be on the road for the WHOLE season this year :lol: :lol: :lol:
Watch this space for thrills, spills but hopefully no fuel fires :shock:
kev_the_mole
Decided to do something about the cooling at the same time as all the other work so with a tiny engine bay and the old Healey problem of hot air sat trapped under the bonnet I reckon that I need a bit of post-engine switch-off cooling. I wasn't going to do it with a mechanical pump so Mr. Summit delivered this nice and cheaply last week.
and then I though maybe a fill of this stuff which due to its low expansion and high boiling point turns the cooling system into a very low pressure system which should help to protect the seals on the Procomp pump.
EVANS NPG+ Coolant is a blend of glycols with particular additives that do not require water to remain in solution. As it remains substantially vapor free in the coolant jacket, liquid-to-metal contact is maintained regardless of coolant temperature or engine load. By bathing the entire coolant jacket with vapor-less coolant 100% of the time, metal temperatures are controlled to such an extent that critical levels of detonation and pre-ignition are never reached. Because EVANS NPG+ boils at 375 degrees F, the need for high pressure in the cooling system is eliminated. The only pressure generated in an NPG+ cooling system is due to the expansion of liquid, never by the formation of vapor. Consequently the build-up of pressure in a system using NPG+ is typically in the range of just 2 to 7 psig and gasket seals, hose connections, and even the radiator core, are under less stress and operate safer and longer.
http://www.evanscooling.com/main25.htm
Now all I need is a timer to give me a short delay after starting and a longer delay after switch-off for the pump and fans. Any ideas?
kev_the_mole
Well not much going on in the mechanical or cooling areas as it's driving time of the year but a long time ago I ordered a hardtop and along with everything else going on I semi forgot about it until last week when it was ready :D :D :D YAY!!!!
kev_the_mole
Thought it was about time for an update. Lost the plot last year after blowing up engine at Castle Combe. Then the crate engine replacement had problems and then my younger son was assaulted and in a coma for two weeks but now it's nearly spring and warm enough to work in the garage.
Here's the engine still in the crate
and out of it's crate with the 'lectric water pump
kev_the_mole
This is day two of the interminable fitting a quart into a pint pot.
Somewhat akin to an automotive hokey-cokey!
'You put the engine in'
'You take the engine out'
'In - out, in -out'
'Shake it all about'
'You do the hokey-cokey and
you go down the pub forlorn of all hope'
I think the rhyme needs a little work on it but I feel it sums up the magnitude of the task :D
I suppose I could submit it for publication in the "Little Goth and EMO Book of Children's Rhymes of Despair"
As the HEI dizzy was bigger than the old one the consensus of opinion was that the bulkhead needed to be moved back 35mm. One suggestion was that it should opened up and then boxed back however we cleverly mounted most of the electrics behind it on a previous incarnation. Or my best idea was that I took a 12lb sledge and make it fit :D
In the fullness of time reason did prevail.
For future EFI a crank trigger was fitted.
kev_the_mole
SOD SOD SOD
After the tin snips came out and the firewall was cut and boxed back.
The new air cleaner and inlet manifold are too tall.
This means that we either have to put the old stuff back and choke the engine (not gonna happen :D ) or my pristine and lovingly restored louvered bonnet is going to have to go and I will have to have a new one with a 'hood scoop' to manage the clearances.
Bugger!
Et voila! Les tin snips came in handy again. I am now officially in the V8 Forum 'biggest hole in bonnet' competition then :shock:
kev_the_mole
First shots of the 'carbuncle'. It was the only practical way to go without dropping all the engine and gearbox mounts.
kev_the_mole
....and then we started it up :cry: :cry: :cry:
....it was apparent that it was rougher than a badger's backside.
The next morning it was discovered with a puddle of water below the exhaust. Pete suspected either inlet manifold or head gasket but after the inlet manifold gasket was found to be blameless the head was pulled and it was obvious that water was getting in from the inlet side.
The view down the bores
The cylinder head
The culprit!
Mark
Post by Mark »
That has to be soul destroying :(
I hope you get it sorted out OK
Mark
Post by CastleMGBV8 »
Ian,
Sorry to hear of your problems, not sure of the relevance of the ex. port picture, i seem to remember you had a problem with a previous head that had been over ported, is that what your indicating is the same problem or is it purely a gasket sealing problem.
I'm no expert on Chevy engines but it looks as if the head/s were not seating correctly and allowing proper compression of the gaskets but I could be completely wrong.
You appear to be using head bolts, any chance they are bottoming out before correct compression of the gaskets ?
