the hurdles are getting lower at last,
And the list of jobs getting a lot smaller,
My 4.8 with a Procharger D1SC Supercharger
Re: My 4.8 with a Procharger D1SC Supercharger
It won’t work on an I pad!
What ecu are you using now?
still running the megasquirt ms2 mate
Your tensioner is bouncing around a lot!
This could mean either spring tensioner has had it?
Your belt length is wrong so the the angle the tensioner acts on the belt is different?
or you have something causing cyclic torsional loads in your belt drive?
Pulley out of align?
Any of these could be bad for your supercharger belt drive!!
That's now sorted mate
Out of line pulley and a worn tensioner
