Judder / Misfire on LPG - Fine on petrol
Eurostang
Post by Eurostang »
Hi all,
My 3.9 Discovery 1 has started to misfire/judder really bad below 2000 rpm and at light throttle. Seems to go away at higher rpms
It is particularly bad on a cold morning and results in a big drop in power / judder.
The system is a Bigas Sequential (SIGN).
I have replaced the plugs to NGK BPR6ES and gapped to 0.8
New leads
New distributor, rotor, cap and ignition module
New coil
Could it be a sticking injector?
I have purchased a data cable to hook into the Bigas ECU.
Eurostang
Post by Eurostang »
I have taken a video, I apologize for the shakey video and background/road noise (It's an old squeaky land rover :/)
https://goo.gl/photos/j3eyGBk1VDk43atj8
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
Air leak or poor electrical connection somewhere would be my starting point.
You say you have new HT leads, if they're standard then ditch them and get good quality 8mm leads.
LPG puts a lot more stress on the ignition system so any weakness will show up on LPG but may not show when on petrol.
I had a judder at high load / speed, which after replacing lots of ignition components turned out to be the MAF. Petrol was fine, LPG juddered.....
Return to “LPG Section”
