nothing serious mate just an axel bearing
i want to try and hook this b@tch up this year
so im swithing to a fully built fabricated ford 9" built by geoff hauser £4500
jay
Turbo & Blow Through Carb resources
Cheers Jaymrmad wrote:hi iain
i got my carb custom built to my engine by these guys http://www.csucarbs.com/ the guys name is kevin and all i can say is that he knows his stuff when i was on the dyno he was on hand for advice
not had any problems with his carb at all
here allso is a link to doin a carb your self very use full http://www.hangar18fabrication.com/blowthru.html
hope this helps
Had a look at both those sites already, think it was CSU who do the hats/bonnets also? (have been recommended them off the american site)
Need to get the car back from its extended holiday first, then start working things out
Wont be going mad with the boost as im not looking for silly HP - ideally want an engine thats not going to need loads of work after every run and has good road manners - time will tell
P.S. good to see you back
mrmad wrote:nothing serious mate just an axel bearing
jay
I hope thats fully fitted
THE SMOKING GNU
thanks its good to b e backIainB wrote:Cheers Jaymrmad wrote:hi iain
hope this helps
here is another site that you may of seen they do very nice hats http://www.superiorairflow.com/
jay
LETS RACE
no mate i will fit it.ian.stewart wrote:mrmad wrote:nothing serious mate just an axel bearing
jay
this is the list of parts
competition engineering fabricated ford 9" housing and back brace
strange 31 spline shafts
big bearing strange ford housing ends and bearings
strange nodular iron s series third member
daytona pinion support
1350 pinion
strange third member bearings
strange 325 gears
aerospace engineering 4 pot billet drag race rear brakes
tru trac differential
all braided brake lines
competion engineering brackets for four link
all the fabrication
power coating the whole axel
compleat new 1350 propshaft
strange double adjustable coilovers and springs
i have taken the 8" off the car he is replicating the mounts on that
LETS RACE
