Blown rangie
Blown rangie
Thinking of boosting my rangie up. Can you buy a supercharger kit that fits underbonnet of a range rover classic.
Bit of advice for you M8. You have posted several threads here with questions about various engine changes and none of them match. Your asking about cams, heads and compression ratios and now a supercharger. All the changes your making to an engine have to match or it will perform badly or worse break. If you want a charger then you need low compression a cam to match and if your doing headwork porting to match as well.
If you want to save time and money then sit down and work out what you want from the engine. Once you have done that then make a new post stating what you want and you will get much better and more accurate answers.
