3.5 supercharging
3.5 supercharging
Hi has any1 fitted eaton m45 to their rv8. I am interested in fitting them to my 3.5 carb engine would like to know if there was much increase in power. Also has any 1 ran m45 with carbs? thanks
Not done it but I am pretty sure the m45 doesn't have the right seals for it to run in suck through mode, you could set it up to run blow through with a carb but it it would be difficult to get the right carbs these days (metro turbo sus would do it but not sure what size they were), a 4 barrel you would have to put in a sealed box, dooable but a right bodge.
Hi, the M45 is the BMW mini one? it is far too small, you might get enough flow with 2 but still it will be operating out of it's best efficiency range, you want something off a similar sized engine, the one off the 3.2 or 4 litre jag is a better starting point. As for cheepest easiest set up, use a rover injection inlet manifold and controle it with a megasquirt ECU or extra EFI from Phill plumb it through an intercooler via a standard throttle body.
- topcatcustom
If you had space then it could be quite a neat set up with twin M45's breathing through an SU each on a standard manifold, not the most efficient or potential set up by far- but should still give a massive increase. Just not much tuning potential. As Mike says they are too small by a long shot, 2 would just about be ok, if you want a single then you need an M112 ideally, or if wet then it'll have to be a big buck sprintex twin screw, or an old skool blower.
TC
- topcatcustom
