Ok - i'll bite.My link above covers singles and twins, we haven't done a quad one yet so lets play. Taking those figures and reducing the cylinders to TWO gives us the data for a quad setup.
So for a 3.9 at 5500 rpm running quad turbos (achieved by setting the number of cylinders to TWO in the calculator) at 5500 rpm, 10 PSI (pressure ratio of 1.75) - you require a turbo that will produce 8lb/min:
http://www.not2fast.com/turbo/glossary/ ... tyCycle=85
Then lets reduce the RPM to 3000 RPM:
that gives us 4.64lb/min. So you need to find a compressor that will produce that amount of air, somewhere close to the middle of the "island" which is the sweet spot in the middle of the compressor map where the turbo is most efficient.
So I find the smallest Garrett GT turbo map I have and plot the data:
Green line is your 1.75 pressure ratio (10psi) and then the intersections show the air flow at 3k and 5.5k RPM. We can see that we are at least on the map, but not close to the sweet spot - so this in theory would work from a compressor point of view. How well two cylinders would spool that turbo is another matter.
Garrett state that this turbo is good for 50-130 BHP on engines with a displacement of .4 to 1.2L. So that does sort of correlate with the calcs I have done above - which means i'm not talking bollocks hopefully.
And I'll say it once more - twins or single will work best - quads is for novelty value.
And here we are - G12's are £512 from ebay:
http://cgi.ebay.co.uk/Garrett-Turbo-GT1 ... 7C294%3A50
So do you want to spend £2k on four turbos or £682 on a single GT35 that will get the job done better:
http://cgi.ebay.co.uk/Garrett-Turbo-GT3 ... 7C294%3A50
Remember - if they dont spool or you want more power - you need to get 4 turbos modified or changed, whereas a single unit is cheaper to upgrade/swap/modify.
Still want to go quad
