sticky injectors
sticky injectors
ive got my car running at last but its only running on 3 or 4 cylinders and i think it might be injectors stuck, are they usually knackered or can they repair,
they can be cleaned, if it has been standing a while soak 'em in injector cleaner to start with, it is worth a go, but they will probably need an untra sonic clean and injector cleaner pumping through them. someone around here was making an injector cleaning rig a while ago.
you sure you have not got any damaged wires???
when i built my car when i plugged the injector plugs on 3 of the plugs pushed the wires out
Re: sticky injectors
If it is only firing on four then bear in mind the system fires each bank of injectors alternately, so you may not have a sticky injector problem. It could be a fault in wiring, injector resistors or ECU.toughy V8 wrote:ive got my car running at last but its only running on 3 or 4 cylinders and i think it might be injectors stuck, are they usually knackered or can they repair,
Check that all the injectors are receiving their injector pulse befor you assume the injector is faulty.
Removing spark plugs leads one at a time to detect if any changes to engine note occur to determine which cylinders were not firing.
You might also get a similar diagnosis by removing injector plugs one at a time.
