Exhaust Manifold Gaskets,
Any one know where to get these gaskets from????
Im running a set at the moment, but when i change the heads i want to replace the gaskets, (ones in the picture i have been loaned)
Im going to open up the exhaust ports to match the gaskets also once i have a set.
the only ones i have found so far are these, which i have been told are catalic ones
the top ones reg???
yes i did Marki,
but when i contacted Jim last year he said he could no longer get them
The ones you're after look like the twin metal composite ones I get from RPI.
you got a picture Pete?
"Here's one I prepared earlier".thev8kid wrote:you got a picture Pete?
The port dimensions are 26mm wide 37.5mm high. The ones I've bought previously aren't as chunky as these but the port dimensions are the same. You can't see it from the picture, but they're about 2mm thick and consist of a fibrous matrix with a wire mesh through the middle of it.
ah yeah seen them before,
im trying to locate the ones that i have in the pictures, as these seem to be the best ones i have used for sealing so far.
correct,Eliot wrote:the topmost ones look very oem. they may be from the later 4.6 engines.
but nobody seems to stock them now, just the ones like greenv8s posted
Sorry those aren't what you want.thev8kid wrote:ah yeah seen them before,
By chance I came across this advert recently which looks very similar to the ones you asked about:
http://www.clever-trevor.net/part/43/ex ... s0091.html
I haven't seen these in the flesh though.
