Having a seriously weird fuel (?) problem on my '83 110 V8.
She starts & runs fine on LPG, but - when started on petrol started with difficulty, ran roughly for about 30 seconds then cut out - repeatedly. Pumping the accelerator prolonged this to about 45 seconds. That was yesterday - today she won't start at all on petrol.
Possibly relevant facts/related symptoms ?
- LPG is a simple single point induction system, injecting into the air intakes of the (Stromberg) carbs. Petrol system is standard as to pump & filter.
- Petrol in tanks is only 2 weeks old.
- New fuel filter fitted about 2 weeks ago, but had been running fine.
- Fuel pump makes the right fast then slower ticking noises on startup.
- Had been experiencing petrol vapourisation problems when running on the hot side in heavy traffic.
- Had just fitted braided fuel hose from filter - fuel solenoid (part of LPG system) - carbs, to try to alleviate vaporisation problem.
- Serious backfire when starting from (very) cold on LPG had blown front silencer box 4 weeks ago, so there is a new box (a pipe run to Y pipe) fitted. This sounds a bit rough on start up on LPG since the start of the petrol problem - with an intermittent burble/rattle from the area of the silencer box until the engine is warmed up.
What I have done so far:
- Reinstated the original fuel pipe; checked all fuel connections for petrol/air tightness.
- Checked the top half of the carbs. Cleaned pistons & needles & checked diaphragms (OK).
- Run the system in the emergency, petrol-only, override mode - no joy.
- Disconnected the LPG solenoid to see if it was the LPG ECU playing up - no joy.
Thoughts and/or advice urgently needed. Not a crisis - can still run on LPG - but we're meant to be going on holiday, towing the boat to an LPG-starved area (West Pembrokeshire) from next Monday !
Sorry for the rather long post - but if I had any hair left, I would be tearing it out !
Thanks.
Landrover 3.5 V8 Fuel Starvation ?
First off, disconnect the fuel line and put a bottle on the end, turn on the fuel pump and see whats coming out at the carb end. If you get a good flow then look to the carbs, think about a vacum takeoff that may have been dislodges after the backfireing, you could easily have blown off a vacum line. Also try replacing the fuel filter again, it may have gotten a load of poop and blocked quickly.
Adie
[/i]
Adie
[/i]
Yes it's a Porsche and yes, it should sound like that!
- The Original Tom
Mine did that when I first got it as the hoses were too close to the manifold and vapour locked. Have you just tried fitting braided hose or have you moved the hoses too?
I had to re-route mine and sling them up over the air intake sides of each carb to aid cooling them - no problems since.
