Strange noise from exhaust.
This is a strange one.
My engine at tick over, through the rev range and full chat is silky smooth. No rattles, not tapping, no ticking nothing. Just that fabulous roar.
But when I rev it and then let it fall back to tick over I get a funny noise. Not a metallic noise, but I kind of fluttering or chattering/puffing noise. Almost like air being drawn back up the exhaust on the last throws of the rev up just before it goes to tick over.
Doesn't do it on the rev up, doesn't do it at any other time, other than when it goes to tick over from being revved, then goes quiet and is silky smooth.
Very odd.
Has anyone else had this?
Mark
Very odd.
Mark
Mark
Sounds to me like unburnt fuel getting int the exhaust and then catching on fire
Add a spark and you would get a backfire of note
Presuming here that u are running carbs
Yep, its a Eddie 500 carb.
Runs perfectly, doesn't bog, doesn't miss fire. Sounds lovely and goes like a stabbed rat.
Should I try and richen up the idle?
Mark
Have a look at my video. 3 minutes in, small burn out at the Bath and West. limiter coming in at 4000 rpm.
8 mins in. Another run up the straight at Bath and West.
Mark
Mark
Mark !
Why is your limiter set to 4000 rpm ?
If its on stock hydraulic lifters I would set the ign cut to 5500rpm ?
If you have the limiter set that low and rev the engine you will no doubt be chucking unburnt fuel into the exhaust system.
Perry
Perry
