Does anyone know if there were different specs for these for the flapper efi or are they all the same?I have one from sep 84 with one part number and another from april 85 with a different one.Both VDP EFI's. Curious to know if they are different and how so.Any info appreciated.
Regards Doug
Power Resistor Pack
- Knows His Stuff
Re: Power Resistor Pack
Hi Doug, Not easy without the part numbers but notwithstanding that a prior owner has substituted a different unit on one of your cars, all 1982-86 Efi rovers had the same spec unit.ozrover wrote:Does anyone know if there were different specs for these for the flapper efi or are they all the same?I have one from sep 84 with one part number and another from april 85 with a different one.Both VDP EFI's. Curious to know if they are different and how so.Any info appreciated.
Regards Doug
Test the resistance of each element for 6 ohm + or - 1 ohm as per this diagram.
If they meet the spec, they are OK.
Ramon
http://www.vintagemodelairplane.com
