Bosch 044 pumps
Bosch 044 pumps
Been looking at the above on fleabay and found one for 87 plus postage which seems a fair bit less than anyone else, is there a way to tell if its kosher or a knock off?
don't nibble on the barrel, pull the trigger!
I have some cheap knock off on the car ( about 50 quit incl P&P) and it holds fine.
Its even on overrun as I only use 1 bar max ( 0.2bar on cruising ) and the rest gets bypassed back on the return hose.
Its on for 6000 mile now where a genuine big name brand high dollar let go already after 500 mile cause it got overheated by not getting pressurised enough ( so it keeps running high revs..).
Use one on my turbocharged carburated Capri.
The pump still does 6.5bar while testing it.
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
Building a GT40 mk2
