ihatesissycars wrote:I have 8 33lb/h red bosch injectors which i got with my ACT plenum which cost the guy i got the lot for over £600.
Injector bargin
- ihatesissycars
If you ask Tim from Act he may sell you the Westfield plenum without trottle body in basic form. That should be in the 300 GBP region if I remember correctly.adamnreeves wrote:You don't want the ACT plenum, you want to use the supercharger thenyou can sell the ACT plenum to me! Then I can stop p**sing about with fabricating my own!
I had a few bits delivered it seems the post office have a handling charge for pasing the box over the counter to you
Fedex or UPS dont seem to have it.
I have a allot of stuff from jegs and they always seem expensive with shipping.
I know have accel 48lb injectors spare good
Venom 55lb injectors spare and crap
ended up with bosch 75lb I think they are.
my engine gained 35lb torque and runs much smoother with the bosch ones in.
Be carefull with them.
Alex
Alex
I was thinking - are there no suitable alternatives off high-po four cylinders (i.e. buy two complete sets) in pintle style......I was thinking along the lines of SR20DET or CA18DET engines from Nissans. Trip to the scrappy might be required.
Are there any common disadvantages to using overtly large injectors for your application - i.e. something like those 75lb ones on a 3.5 - total overkill (aware of that) but would it actually cause problems?
Lewis wrote:I was thinking - are there no suitable alternatives off high-po four cylinders (i.e. buy two complete sets) in pintle style......I was thinking along the lines of SR20DET or CA18DET engines from Nissans. Trip to the scrappy might be required.
yes overly large injectors is not good. Quoted from http://www.megamanual.com/v22manual/minj.htm#size
"Injectors that have too large a flow rating will make it difficult to tune the engine at idle and cruise. Injectors that have too small a flow rating can starve the engine of fuel at full power, and seriously damage your engine."
Depending on the ecu and or the injector opening time you might not be able to control the injectors at low rpm I.E their minimum fuel flow might be too high. This can lead to rich low rpm at best or not running at worst.Lewis wrote: Are there any common disadvantages to using overtly large injectors for your application - i.e. something like those 75lb ones on a 3.5 - total overkill (aware of that) but would it actually cause problems?
On my engine we were taking the 48lb to 70% duty at 4000rpm.
So I already bought the 55lb one and we tried these.
the engine ran real lumpy testfiring them one was only doing half the job
the dyno place had a injector cleaner and balancer. they were supposed to be matched to=/-1% try =/- 30%
hence why we ended up with the 75lb's. these are low impedance but we use a motec ecu which drives them on a square wave pattern and is much more precise than hi impedance. we got an instant 30lb torque at the same given rpm.
I think having the injectors tested is a good investment, cheaper than a new piston
If this seems to be away from subject the 55lb injectors came from usa all brand new It'll cost more to return them and mess around with credit card refunds than the difference between buying new ones here.
Alex
Alex
