i have just won an oil cooler on ebay,
i gather this one got missed as all the others i seen on there go for around £40-£90
this one i won for £27 in p+p (did finish at 9.20am, thank god for ebay on your mobile fone)
i have a sandwich plate with two 3/4 take offs but no cap for it i think its called a mushroom top? are these available round cap with rubber sealing ring and a square type fitting on the front (for tightening up???),
i was going to use the oil pump base with the remote take off's but can't find the one i had before
these aint cheap now are they?
eBay bargain for me 13 row oil cooler
no idea if you can buy the cap on its own but here is the site, http://www.thinkauto.com/takeoff.htm
I think i have cocked up
the oil cooler has arrived, and its a nice bit of kit,
BUT:
what size are used on rovers as standard? 1/2 bsp or 5/8 bsp?????
BUT:
As far as I know 5/8 bsp doesnt exist. It would be 1/2 or 3/4 bsp.
my take off aint 3/4 mate
thats why i thought i should ask
on the 3.9 RR it has a take off plate for an oil cooler, what are these?
are they 3/4? if so i have been sent the wrong cooler.
I didn't know the 3.9 had a cooler takeoff, I thought you had to use either a new pump base or sandwich plate. I know my mocal remote filter kit is 3/4 which is what the likes of merlin and europa recommend for the Rover.
Edit..... I should say you can use the smaller size but you might find your oil pressure will drop because of it.
i'll try and get hold of a 3/4 fitting to make sure the oil cooler is 3/4
