Engine stand help
Engine stand help
I'm a bit embarrassed asking this but how do I connect my 71 Ford 302 block (from a Torino) to the engine stand I have bought?
The engine stand has the four connectors but I don't know how to bolt it on or what bolts I need.
Any help would be much appreciated as I'm keen to get building!
Thanks,
Phil
Thanks,
Phil
- HairbearTE
- Guru
Get bolts made up for the job and use the spacers that come with the stant (if they did). I had colne valley fasteners make up some grade 8 bolts for me. Basically I leave an unthreaded shank on the bolt that is equal in length to the length of the spacer tubes+the thickness of the 'arms' on the stand and then minus a mm or so. This is so that you can get it tight enough to let the spacer tubes do their job. I'll post a pic of some of my stand bolts tomorrow if I get a chance.
Thanks for the replies!
So it really is just a matter of (grade 8?) bolts through the holes in the stands 4 "arms" to the bellhousing connections?
I wasn't sure if some bits (extensions to the arms say) were missing or if 4 bolts would be up to the job of supporting the weight... and didn't want to find out the hard way!
This is the stand I've got (although this only shows 2 "arms"): http://www.machinemart.co.uk/shop/produ ... gine-stand
Some pics would be great HairbearTE!
- Pocket rocket
- HairbearTE
- Guru
Here are some of the bolts I have had made by colne valley. The smaller ones are for use with shorter spacers and were for a four pot I once built. The larger ones are Rover v8 fitting. In the other pic you can see the spacers in use. The spacers are important bacause when fitted properly they take the strain off the bolts and firmly locate the engine on the stand. Without them the engine would hang loosely on the stand. When I needed bolts made up I drew a scale drawing of what i wanted and posted it off with a bellhousing bolt so they got the thread right.
Thanks for all your help!
Do you mind my asking how much it cost to have these special bolts made up? I've asked Basil's Bolts and was told that it would be "mega money" to have some made Still, I don't want to skimp and have the block drop to the floor!
Thanks again
Thanks again
- HairbearTE
- Guru
