Will need a gasket set shortly.
Anybody had experience of the multitude offered on Ebay.
I suspect the composite inlet manifold and rubber rocker box gaskets are a must.
With Composite head gaskets if you want to lower the compression.
Gasket sets
why not check the discount section of the forum and contact one of the companies there, at least you know they will be genuine sellers,
- jefferybond
Re: Gasket sets
Definitely get the composite inlet manifold gaskets! Cork rocker box gaskets are OK though, especially if you don't remove them that often.TVRTASMIN wrote:Will need a gasket set shortly.
Nothing wrong with the tin head gaskets either, but I guess that depends on what CR / heads you are using.
Jeff
Re: Gasket sets
Are these sorted now, about 6 year's ago I was told not to use them, and to use the tin.jefferybond wrote: Definitely get the composite inlet manifold gaskets!
Jeff
Also for the extra few £ id get the rubber rocker gaskets. £8 a pair inc delivery.
