Ive seen quite a few pictures of rv8s using poly/multi-v pulleys on the alternator, water pump and crank.
Would these be generally one off, made by an engineering firm or can you buy them as a kit? If you can get them as a kit, I would be grateful for info.
Steve
engine pulleys
unless you can use the 4.0-4.6 ones and get them spaced properly they will be made to measure. The crank one should fit ok with a spacer but the water pump will depend on what your using and you will have to use a 4.0-4.6 alternator to get that one to fit. I made my own ones but I am using a P6 pump so nothing else would have fitted.
