smoke!!!!!!! lots of it!!!!!
Help!
bought a sd1 with 3.9, rebuilt? engine. after 300 miles of use, it started to pink and turned day into night behind me!!!!. Ran rough so creeped home.
looked for obvious signs and eventually had heads skimed due to very faint maching mark accross oilway into cylinder. Rebuilt but exactly the same. Took car into local garage and they changed the oilrings even though there was no breakage etc. No signs of gasket probs so now pulling hair out!!!!! Starts 1st time, ticks over roughish but as soon as you touch the gas it pours smoke out! Even disconected brake vacuum pipe in case drawing fluid back. Help really needed!!! Is this a sign of liner failure?
Thanks,
Tony
Thanks,
Tony
Re: smoke!!!!!!! lots of it!!!!!
Tony, IF you are running an GM180 Auto transmission and the smoke is white then the modulator valve on the rear of the transmission may have failed sucking ATF into the manifold.tonydancer8 wrote: bought a sd1 with 3.9, rebuilt? engine. after 300 miles of use, it started to pink and turned day into night behind me!
Tony
Modulator Valve for GM180 Transmission
64 Vacuum modulator and oil seal
65 Push rod
66 Modulator valve
67 Modulator Sleeve
Couple of things to look at
1) Check all spark plugs - it may just be one oiling up badly - then concentrate on that one cylinder
2) Remove Rocker cover and check valve stem seals are in place
3) Crank over engine and watch to see if valves look like they are moving correctly on suspect cylinder
4) Report back which cylinder is oiling and I bet someone on here could advise where to look for a bad gasket etc that would allow oil into the cylinder area.
thanks, everyone,
comp test between 165 175, all valve stem oil seals changed on first head removal. Someone has suggested using 20/50 oil, but why should it
have started after 2or 300 miles? will double check your ideas sat morning
before taking engine out again!!!!!!!
thanks again,
Tony.
ps as anyone got a holly 390 for sale as i also run a rover v8 powered dragster.
thanks again,
Tony.
This came up on another thread a few days ago, have you got the positive crankcase ventilation set up properly? If not the pressure in the crancase can force oil down the valve guides and make for a very smokey engine, it happened on mine after a full rebuild and re-installing the venting system completely cured it.
Kevin Jackson.
Kevin Jackson.
Well done guys( and girls) last reply re vent pipe lead me to a kinked pipe that had been ramed down a hole in the inner wing, heads reskimmed, new oilrings fitted for nothing!!!!! thanks again and now its time to sort our rv8 dragster out! Carb knackered1 anyone got a holley for sale that they know is ok for rover v8?
cheers again,
Tony
cheers again,
Tony
