Range Rover 630R Engine
Spongo
Post by Spongo »
Well I finally started to strip the engine in the 630R after finding the oil pump drive nearly stripped, good news is that the cam is totally mint not a mark on it so I have decided to rebuild myself with new bearings a new oil pump (standard so it doesn't overstress the oil pump gear) and some new lifters as they were rattley (probably due to oil contamination).
I must say though that some of the engineering I cam across that was done by Overfinch is completely rubbish like grinding bolt heads off to make the water pump fit :evil:
Range Rover 630R or otherwise known as the Money Pit
MS2 with switch MAPS for LPG
Techedge Wideband Sensor
They did go bust around that time as I recall, so the current Overfinch is not the same as the old one.
Spongo
Post by Spongo »
True and now they only do bodywork and showy stuff, still at least the prognosis for the engine is not quite so bad :)
