Engine Vitals Senders!
- topcatcustom
I have an offy 360 manifold, no temp sensor fitted currently but I need to get one so can someone tell me which it needs? I think I will also fit a new oil pressure sender for peace of mind, interim cover- is there a specific part number?
TC
If it's a smiths gauge, no idea about oil pressre one's tho
http://www.v8forum.co.uk/forum/viewtopi ... intermotor
So thats where it went !
- topcatcustom
err
I think it was the fuel tank gauge that was also fed from it, depends on what your running for them ?
If the gauges are hot wire types, they usually have a voltage regulator. You can tell by rotating the gauge quickly in the hand - the needle won't move with a hot wire type but will with moving coil or moving iron. Most fairly recent ones are hot wire.topcatproduction wrote:Intermotor part number 52730
Thankyou! I forgot about the 10v stuff though! I have some smiths gauges and just got to buy a new water temp and oil pressure- do I run a voltage dropper over all the gauges? The ones I have are classic stag ones I think.
You might consider making up some adjustable voltage regs - they only need a few cheap components. With one per gauge you could adjust that gauge to read correctly at the 'important' part.
- topcatcustom
Hi Tom
Generally a mechanical oil pressure gauge is viewed as more reliable (accurate) but have the worry that if they fail you risk loosing your oil and the gauge and sender are a matched pair. An electrical water or oil temperature gauge is commonly thought to be better. However in both cases an electrical wersion offers more scope for a calibration circute to increase accuracy, rather than relying on the factory 7 second go/no-go test!
- topcatcustom
Cheers guys, due to neatness I am using the standard mx5 oil pressure gauge which DOES have a scale on it, however the water temp gauge doesn't- so I have installed a smiths water temp gauge and got a new sender, part no. 52730 which is standard on all old triumphs, rovers etc of the day I think.
Does anyone know the size of the threaded hole in the offenhauser manifold? I haven't tried it yet but the sender looks too small so will maybe need an adapter...
TC
- topcatcustom
- topcatcustom
The water temp gauge is the same as this one
http://cgi.ebay.co.uk/Classic-Smiths-2- ... 3efe15c778
The needle does move as you rotate the gauge so not dampened, 12v or 10v?????
TC
- topcatcustom
After getting a 10v stabiliser I found that the Smiths gauge just wasn't accurate, so I bought a new durite gauge and sender, http://cgi.ebay.co.uk/DURITE-WATER-TEMP ... 335bfe3697
Do you think I should get something like this to stabilise the voltage to 12v or will it be ok on the car at alternator output voltage which is about 14.5v?
http://cgi.ebay.co.uk/5V-9V-12V-24V-Vol ... 27b0db607f
TC
