Hotwire Tune resistor wire colour and ohms rating.
Hope this helps,
NO resistor Limp Mode.
RED 180ohm - Australian 3.9 cat.
GREEN 470ohm - UK non cat.
BLUE 1800ohm - Gulf states 3.9, or Europe & UK 4.2 non cat.
WHITE 3900ohm - Europe & UK 3.9 (or 3.5 Disco) Catalyst
Hotwire Tune Resistors
If one knows the resistance value (which Tony has kindly provided), a trip to Maplin to buy a suitable resistor is by far the cheapest way to do it. Then you just have to wire it in.
The resistor doesn't directly affect the fuelling. The ECU reads the resistor value, and selects a fuel map / other operating parameters depending on the value. The spectrum of resistor values will be divided up into bands, so the exact value doesn't matter.
This is a normal technique to enable selection of more than two values on a single input wire. If there were only two maps, one would have link / no link. But more than two, and you do it like this.
So
If you put in a variable resistor that changes between the min and max above
Could you literally change the map on the go by turning a resistor?
How much?!!koopsterman wrote:Just had a look on ebay and there is a blue one and a white one on there from the same place at 20 and 25 quid - but alas no green one !
Regards
Maplin is your friend...http://www.maplin.co.uk/p/metal-film-2w ... stor-d470k
44p...
