Engine misfiring - cant find cause
Andrewrv8
Post by Andrewrv8 »
I fitted a 4.6 into my p6 recently running with edelbrock 500. It ran rough and seemed to misfire on 4 cylinders (5,6,7+ 8). Using a p6 timing cover and distributor (electronic). Believing it could be due to warped heads I removed the engine and fitted another. Replacing the cam with a new 4.2 item and steel timing gears and duplex chain etc. Strangely this engine suffers with the same rough running and misfire on cylinders 5,6,7 +8. This surely is no coincidence. I,ve swapped leads etc to eliminate failing leads. Any suggestions? thanks :?:
Is the Eddy 500 a double barrel carb on a dual plane manifold?, one barrel of which feeds cylinders 5,6,7,8?
Andrewrv8
Post by Andrewrv8 »
It is a 4 barrel, was on a dual plane but I've now changed manifold to an old unit I had. Not too sure what it is but has intake holes for nos and is dated 1987 underneath. Looks like left side of carb feeds left bank and right feeds right bank. Hope that makes sense. Think it could be carb related? The fumes are terrible
If it's dual plane, one carb should feed the inner two on one bank and the outer two on the other bank. And the other carb the rest of them.
If one carb is doing one bank, it'll never work very well......
Andrewrv8
Post by Andrewrv8 »
Chris, I agree with you, but it worked on my last engine with holley 600 without any misfiring issues. Not the best manifold I admit. The first 4.6 I fitted I used an Eddy performer and it still misfired. Just tried an different coil - no improvement
Andrewrv8
Post by Andrewrv8 »
Problem solved!! I feel rather silly but I had not noticed a vacuum port on the rear of the carb (presumably for brake servo?) which was wide open :oops:
Runs like a watch. Will upload on youtube over the weekend
sidecar
Post by sidecar »
Andrewrv8 wrote:Problem solved!! I feel rather silly but I had not noticed a vacuum port on the rear of the carb (presumably for brake servo?) which was wide open :oops:
That is a big hole at the back of the carb! Anyway its good that you'e sorted it out!
Andrewrv8
Post by Andrewrv8 »
Yes, ahem thanks. I still cant work out how to get pics on here but here is a link to the car on youtube -
Triumph TR7 V8 3.9efi
SimpleSimon
Post by SimpleSimon »
It takes a man to admit he cocked up 8-) she spins up nicely in that vid :D
:whs
