has any one used a rebild kit from ebay with any luck for the lt 77 5 speed
mines crunching 3rd and very slight whine just audible
thanks rod
lt77 rebuild
lt77 rebuild
rover sdi v8 5 speed 3500 with megasuirt cost me 500 bucks with 6 months rego was on a truck going to the recyclers but i saved it.
ROD BAKER
ROD BAKER
- davemgb
- Helpful or Confused
Rod,
Surprised no replies yet!
I have not tried a kit off Ebay but have rebuilt a number of boxes and if the box is crunching into 3rd I would expect the synchro teeth to be damaged so budget for a new third gear. You will also need the shims to set the layshaft and mainshaft endfloats - early 2wd boxes use smaller diamter shims than 4wd which are getting hard to get.
Good luck.
Good luck.
