What's involved in changing an electronic speedo drive to a cable speedo drive on an LT77 'box. Is it too much to hope that it's just a straight swap?.....
Another LT77 Question...
Looks like it should be a straight swap:
http://www.rimmerbros.co.uk/rimmer/rove ... Transducer
Obviously you need the cable, drive gear, and all the bits associated with the bearing and retaining clips as shown on the exploded diagram.
- russell_ram
I can confirm 100% that it's a straight swap - you'll need all the bits in the Rimmers pictures - even the clamp is different.
I doubt very much if you'll get away without having to recalibrate you speedo though as the available gears only vchange the cable speed by a few % - you might be lucky though.
Russ
Russ
http://www.speedograph-richfield.com/
do corrector gearboxes so you can get the speedo working correctly.
- Pocket rocket
I'll do you a swap for a manual one for an electronic one.
I don't seem to have the clip that holds it in, also I don't have the cable.
