Hi Did they ever used Speed Tranducers,
As I will be running a digital dash, so need a digital speed output, can a retro fit to a SD1 or will I have do it another way.
I will be running a Emerald ECU and Race Tech. DL1 and Dash2. these are fully programable.
Leigh
LT77 Speed Tranducers
- russell_ram
Certainly did - late model SD1 . I use one with a Smith electronic speedo, works perfectly. They are a hall tranducer though, not an inductive probe so you'll need to check with manufacturer that your dash can use a hall output. I sure I can find the wiring diag for the smiths speedo if you needed it.
Good thing is electronic speedos are just so easy to cal - a gentle cruise down the road at a fixed 60mph (using satnav) and alter the pulse/mile number to fix the error.
see here
http://www.rimmerbros.co.uk/rimmer/rove ... Transducer
Russ
see here
Russ
Thanks for advertising the one I was bidding on. and lost Grrr.
Even tho it did not sell last time.
