prop
prop
another Q before i start with putting the rv8 in my sierra i just want to get everything done so i can crack on with it is there any easy way of bolting up my prop to a lt77 or will i have to get one custom made the car is a 2.0 dohc saphire
thanks
thanks
I think you will end up with having to get one made, as the LT77 has a flange on the back of the box, and as you are aware the diff also has a flange, so the prop you need HAS to have a built in slider joint, I have never had much success with the SDI CV prop, Most places that make props have the sliders in stock so it should not be a problem
Last and only prop I have had done at Reco Prop cost me £475, needless to say I was not impressed, there are lots of companies dotted around the country who will make props for you and i am certain there will be one nearer than RecoProp.
Bailey Morris are in St. Neots.
I've had good service from both Bailey Morris and Reco.
http://www.baileymorris.co.uk/
I made the prop for my Morris myself, using an SD1 prop and a Sherpa prop. Totally coincidentally they are the exact same size tubing, though one is a cv joint on a UJ. I made a 6" long steel sleeve tube that tapped lightly into both props to line them up and I welded round it, also added a couple of keyhole welds on each tube.v8saph wrote:thanks guys it needs to be as cheap as poss as its just a track toy not a daily drive if it just needs shortning i have a guy that can do it i wil have to way it up when the limp is in
Hows it holding up paul i need it strong enough for real hard launches etcPaul B wrote:I made the prop for my Morris myself, using an SD1 prop and a Sherpa prop. Totally coincidentally they are the exact same size tubing, though one is a cv joint on a UJ. I made a 6" long steel sleeve tube that tapped lightly into both props to line them up and I welded round it, also added a couple of keyhole welds on each tube.v8saph wrote:thanks guys it needs to be as cheap as poss as its just a track toy not a daily drive if it just needs shortning i have a guy that can do it i wil have to way it up when the limp is in
i hope i am able to do this as it would save loads of money
- Nick Moore
I was wondering about the need for a slider joint? The diff and engine/gearbox are both bush-mounted to the chassis in the Sierra, so neither will move around much. I ask because my other car, a Triumph Herald, has a bush-mounted diff and solid propshaft with no slider. Is the slider to avoid stressing the UJs with movement of the engine?ian.stewart wrote:I think you will end up with having to get one made, as the LT77 has a flange on the back of the box, and as you are aware the diff also has a flange, so the prop you need HAS to have a built in slider joint, I have never had much success with the SDI CV prop, Most places that make props have the sliders in stock so it should not be a problem
It's not a bodge if no one finds out!
there needs to be an amount of play to facilitate getting the prop betewwn the flanges, and the movement of the engine /box fore and aft under normal driving conditions will force a load up thru the gearbox output shaft , or knock out the pinion bearings
