LT77 clutch.
LT77 clutch.
I have fitted an LT77 to the back of a 3.9 and when I tried to move the clutch release arm through the bellhousing[using the shank of a hammer] it feels solid.Should I be able to move the lever by hand?I want to make sure the clutch is correct before fitting it in the car.
Re: LT77 clutch.
Not tried without the slave cylinder but would be suprised if you could move with hammer shaft.nickm wrote:I have fitted an LT77 to the back of a 3.9 and when I tried to move the clutch release arm through the bellhousing[using the shank of a hammer] it feels solid.Should I be able to move the lever by hand?I want to make sure the clutch is correct before fitting it in the car.
George
