arp flywheel bolts
Seight-V8
arp flywheel bolts
Post by Seight-V8 »
hello all,
can anyone confirm the sizes of the ARP flywheel bolts for the rover v8?
bolt head size & socket required
length & thread.
The ones I have don't have much space for the socket between the bolt & the crank shaft where the spigot bearing goes.....
Not sure if the head sizes on the bolts I have a correct.
cheers
scott
Seight-V8
Post by Seight-V8 »
sorted already, I've got the wrong ARP flywheel bolts....
I have 200-2802 bolts which are 7/16-20 1ins long 3/4 socket....
but should have
200-2807 bolts which are 7/16-20 1ins long 5/8 socket....
time to buy some new ones.
scott
Blown v8
Post by Blown v8 »
Mine were really tight,I had to turn a socket down to get them to fit,
(I think that makes sense !)
Seight-V8
Post by Seight-V8 »
Cheers looks like an option to me.
Will get a new 3/4 socket and get it reduced at work to make it fit.
Regards
Scott
DEVONMAN
Post by DEVONMAN »
I just ground away the outside of the socket. Not as pretty as doing it on a lathe but it got me out of trouble on a Saturday afternoon.
Denis
Likewise, had to lathe a socket when I fitted them on mine
What is the problem with standard bolts?
Chris
I too had to turn down a 3/4 socket in a lathe to fit the bolts
ChrisJC wrote:What is the problem with standard bolts?
Chris
Probably not a lot really...but ARP are nice lol
