Does (or could) anyone have a SD1 SU linkage photo?
Posted: Wed Dec 28, 2011 11:37 am
I've had an issue with my landie which has had an SD1 V8 retro fitted with LPG where only the LPG would work.
I suspected the carbs (twin HIF 44), and as I want to go through the landie gradually fixing her up, I thought I'd take them off and rebuild them.
My suspicion was correct, most things that should've moved, didn't!
So after rebuilding them, following all the info documented in the SU manuals, I found one piece of valuable information missing... how to link the two carbs together. I have a plate with a ball-joint on which I can't figure out how it fits to the carb.
To be fair I only spent about an 30mins trying at the end of the day, when my patients weren't at their best. However I don't get that much time to work on the ol' girl, so if someone has a Rover SD1 enging fitted to anything with the twin HIF 44, could you possibly take a pic and post it on here please?
Either that or point me towards where I could find the info. If it is in a manual somewhere, I don't mind buying the manual as long as I know it's in there!
Thanks for your help.
