Water Pump Question for Rover V8 Gurus out there!
Posted: Wed Nov 02, 2011 11:53 am
Good Morning!
I'm really hoping some one can help me, as I'm finding it very difficult to gain information on this matter.
I have an '88 Land Rover 90 factory fitted with a 3.5, running SU Carbs. The vehicle has PAS and originally had Air con which was removed by the previous owner. Engine number is 25G01635A
Anyway, the water pump bearings are starting to get a bit noisy so I hope to replace it very soon. However this vehicle is my daily driver and any down time would be a bit of a nuisance so to combat any possible seized/broken/corroded bolts I wish to order replacement bolts along with the pump.
The problem is identifying which bolts I need! I have looked at parts diagrams but they make little sense and the last thing I want is to have replacement bolts but not the correct ones!
So I would be very grateful if anyone can provide me with part numbers or sizes of the bolts I need so I can be sure I have the correct replacement bolts?
