Rover P6 part no. 610029 special bolt 3/8 UNC x 1 1/8"
Posted: Sun Oct 30, 2011 5:42 pm
by al mackenzie
Hello chaps. Hope somebody on here can help me. I'm looking for two more of the 'special' bolts with which to attach a warm air collector to the driver's side exhaust manifold of my Rover P6 3500. Three of these bolts attach the manifold to the cylinder head, they have a long hex section which is threaded to accept a smaller bolt to hold the warm air collector in place. I want to fit the US export air filter canister which had a cold air intake from a scoop on the bonnet and a warm air feed from the engine, with a flap regulating the mix of warm and cold air. Can't just fit the scoop without also having the corresponding set-up n the engine, that would be too easy! Cash waiting, hope somebody can help me out!
Posted: Mon Oct 31, 2011 5:45 am
by unstable load
If you get stuck you can improvise that.
Get a length of threaded rod with the right pitch thread and a few nuts to make up the thickness of the spacer you want and thread them onto the rod leaving a bit each side to screw into the head and to fit a washer and nut to the other end.
Posted: Mon Oct 31, 2011 9:04 am
by ged
PM sent.
Posted: Mon Nov 28, 2011 7:38 pm
by al mackenzie
Many thanks to Ged, who kindly made me three of these otherwise impossible to find 'special' bolts out of stainless. Excellent. Another problem solved through this useful forum and it's helpful members. :D
Posted: Mon Nov 28, 2011 9:38 pm
by ged
You're welcome Al. :D
Best Regards
Ged.
