Fuel pumps
Posted: Thu Oct 20, 2011 10:20 am
by Pitschi
Hi there,
need some advice. Built this:
http://www.mez.co.uk/rovermanifolds/PICT7625.JPG
and the question is: is one Holley fuel pump enough? Had no problems to run a high tuned Chevy with one pump but have seen many racing V8s (Cobra etc.) with four pumps!!! Just for the case one or two are missing? The RV8 is not to compare with but there a still four Dellortos :-) and before I order a fuel tank, two outlets are better anyway I think. One or two pumps?
Any ideas?
Pitschi
Posted: Thu Oct 20, 2011 11:01 am
Hello
Nice to see you back on here
If it is a road car I would keep it simple and use one (provided it is big enough), for a circute car for short duration races I would say the same. If you are endurance racing (anything more than about 2 hours) then I would run two pumps and double plumb it from tank to carbs but have it set up main/ reserve ie only one set running at any time and you have to deliberatly change from one set up to the other.
Can't see why you would have 4 pumps unless you thought the car wasn't heavy enough and it was too reliable.
I would avoid running multiple pumps where you are trying to get around not having a big enough pump, get the right sized pump, it is out there, otherwise you are just asking for an unreliable set up that is difficult to fault find.
Posted: Thu Oct 20, 2011 11:18 am
by Pitschi
I have one brandnew and a used red top Holley. I will mount both just for the case one is failing and I can switch just to the good one.
The car is heavy enough Mike :-)
Posted: Thu Oct 20, 2011 12:17 pm
What car is it??
Posted: Thu Oct 20, 2011 12:27 pm
by Pitschi
Posted: Thu Oct 20, 2011 12:57 pm
That is nice,
that chassis looks as if it is a serious piece of engineering, should be nice and stiff, but as you say it looks heavy.
Posted: Thu Oct 20, 2011 1:01 pm
by Pitschi
Thanks,
Will get weighted after it's finished, so far away :-(
