cold running O2 readings
Posted: Thu Oct 06, 2011 10:48 pm
what sort of readings should i be aiming for when starting from cold?
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
https://www.v8forum.co.uk/forum/
As lean as you can that allows the engine to run nicely.Coops wrote:what sort of readings should i be aiming for when starting from cold?
Mines the samesidecar wrote:Here's a theory....
The AFR should be the same as when the engine is hot, the amount of fuel that you need to feed the engine will be more than when the engine is hot due to a lot of it sticking to the cold inlet track walls along with some of it returning back into a liquid form from its vapour form.
I run an Eddy 500 with no choke fitted at all, when my engine is cold the lambda probe show all the mixture circuits to be a bit leaner than when the engine is hot due to the loss of fuel burnable fuel in the inlet manifold.
Of course the above could be a load of old...
