gearbox help
Posted: Thu Sep 22, 2011 3:40 pm
by dandan81
hi guys if i was to get hold of a BMW zf4hp22 gearbox can i change the bell housing from a range rover zf4hp22 gearbox on to the BMW one,
the reason i ask is i need a rwd gearbox for my v8
any other suggestions :?: :?:
Re: gearbox help
Posted: Thu Sep 22, 2011 4:22 pm
dandan81 wrote:hi guys if i was to get hold of a BMW zf4hp22 gearbox can i change the bell housing from a range rover zf4hp22 gearbox on to the BMW one,
Yup. Early 4HP22 were cable control only - later ones some electronics, so get the right one.
What vehicle is it going into?
Re: gearbox help
Posted: Thu Sep 22, 2011 4:37 pm
by dandan81
how do i go about changing the input shaft from the car gearbox to the range rover one is it a easy job
Posted: Thu Sep 22, 2011 6:18 pm
The input shaft is the same. You just need to change the bellhousing, which doesn't even mean opening up the internals of the box, it's just on the end.
Re: gearbox help
Posted: Thu Sep 22, 2011 10:42 pm
I'm not certain, but I'd guess the Rangie torque converter would fit the BMW box. So you'll need the bellhousing, TC, drive plate and spacers, etc.
