simply wiring alternator to battery
Posted: Tue Jun 14, 2011 3:43 pm
by roverv8tom
how would i simply do it its an old lucas alternator off v8 is it just a case of the two screw connectors going from positive to negative on battery??, only problem is dno which is positive and which is negative
Posted: Tue Jun 14, 2011 7:12 pm
by Will Reeve
The alternator case is -ve. So battery return is through the alternator bracket, then either through the engine block to battery -ve or you attach a thick cable from the alternator bracket to chassis like I did to make sure of a nice low ohm link!
Posted: Tue Jun 14, 2011 8:06 pm
One will go to battery +ve, the other should go through a small bulb (charge light) to battery +ve.
Re: simply wiring alternator to battery
Posted: Tue Jun 14, 2011 10:20 pm
by DEVONMAN
roverv8tom wrote:how would i simply do it its an old lucas alternator off v8 is it just a case of the two screw connectors going from positive to negative on battery??, only problem is dno which is positive and which is negative
You really need to identify the type of alternator. For instance if it's a 11AC type then it will need a external regulator like a 4TR box. Later types just have a postive to the battery and another smaller connector to the IGN warning light. The earth is provided through the body of the machine.
cheers Denis
