what clutch
Posted: Mon May 23, 2011 1:36 pm
by yoldy
i am looking to buy a clutch kit for my capri,but my supplier says theres a choice of two can anyone advise on any part numbers please
im useing a 3500 rover v8 and a lt77 5spd box
cheers
what clutch
Posted: Tue May 24, 2011 6:42 am
by yoldy
the suppliers are saying that the differences are in the cover,one has flat fingers and the other has raised fingers,what one should i use???
Re: what clutch
Posted: Tue May 24, 2011 7:35 am
by DEVONMAN
yoldy wrote:the suppliers are saying that the differences are in the cover,one has flat fingers and the other has raised fingers,what one should i use???
If your release bearing is a round faced type then a flat finger clutch cover is the one to use.
Cheers Denis
clutch
Posted: Tue May 24, 2011 5:44 pm
by yoldy
clutch is sorted!!!!going to fit the clutch and fly wheel tonight!!!
thanks for the info(once again) :D
hydrolic to cable
Posted: Wed May 25, 2011 7:07 am
by yoldy
im going to give this a try,in theory it should work.modified lt77 release forkto take a capri clutch cable and drilled a hole in the lt77 bellhousing to mount the cable to the box.same set up as the ford type 9 box
Re: hydrolic to cable
Posted: Wed May 25, 2011 7:52 am
by DEVONMAN
yoldy wrote:im going to give this a try,in theory it should work.modified lt77 release forkto take a capri clutch cable and drilled a hole in the lt77 bellhousing to mount the cable to the box.same set up as the ford type 9 box
Not sure that will work. The LT77 fork is normally pushed by the slave cylinder and a cable will pull it. You would need to use a ford type fork and pivot it on the oposite side of the bellhousing.
Cheers Denis
clutch
Posted: Wed May 25, 2011 2:31 pm
by yoldy
im using the lt77 fork what i have drilled and cut to hold the cable end.and drilled a hole in the bell housing on the opposite side of the original slave cylinders position .the ford cable has a threaded end with two lock nuts that will hold it onto the box,one on the inside and one on the outside. its basicly the same as the type 9 ford set up ,trial and error!!!lol...lol...
Re: clutch
Posted: Wed May 25, 2011 6:21 pm
by DEVONMAN
yoldy wrote:im using the lt77 fork what i have drilled and cut to hold the cable end.and drilled a hole in the bell housing on the opposite side of the original slave cylinders position .the ford cable has a threaded end with two lock nuts that will hold it onto the box,one on the inside and one on the outside. its basicly the same as the type 9 ford set up ,trial and error!!!lol...lol...
Deffo trial and error. You will find that the pedal will be hard to push as the lt77 fork ratio will be nothing like a normal ford cable type fork. The pedal will also move the clutch too much unless you put a limit stop on it. Also the cable force will be higher than originally designed for and may break more often.
Good luck.
Cheers Denis
Posted: Thu May 26, 2011 5:07 pm
by Pocket rocket
It will work - that's the set up I have on my cobra
Posted: Thu May 26, 2011 5:33 pm
by DEVONMAN
Pocket rocket wrote:It will work - that's the set up I have on my cobra
You probably have a different pedal ratio on the cobra.
Cheers Denis
