4.6 V8 Carbs - Help Needed
Posted: Mon Mar 19, 2007 6:57 pm
by 4646464646
Hi all,
Just put a 4.6 V8 in a Comp Safari racer but not sure what to do with the Carb side. We put 2 SU's on it from a 3.5 SD1 and it ran really very badly! No go at all.
What needs to be done to the Carbs to make it run with a 4.6 V8?
How do you set them up?
What other options are there?
Cheers!
Posted: Mon Mar 19, 2007 8:19 pm
by chodjinn
probably best bet with carbs is get a Wever 500 and have it jetted for the 4.6. The SUs you put on will njot supply enough fuel - they were off a 3.5 after all - so would need rejetting at the least. :)
Posted: Mon Mar 19, 2007 8:23 pm
by 4646464646
From a financial point of view i'm thinking it would be a lot cheaper to referb the SU's and not be spending £500 on a Weber.
What would I need to do the the Carbs? New needles? If so, how do i match them to the engine?
Posted: Mon Mar 19, 2007 10:50 pm
by Eliot
weber 500 might be a bit of nightmare on a comp safari motor. My dakar used to cough and stumble just pulling into my road.
Theres some info on mods for the SU manifold on a 4.6 described here:
http://www.mez.co.uk/TuningTheRoverV8-pt6.html
Eliot.
Posted: Mon Mar 19, 2007 11:42 pm
by 4646464646
Good site. Very usefull information.
Cheers!
Posted: Tue Mar 20, 2007 3:15 pm
by minorv8
I have run both SU´s and Weber (Edelbrock 500) carb on my 4,6 and SU´s area really restricting the engine. They are only used for MoT visits. I don´t remember which needles I have but I can check. I think they were BCA´s.
EDIT: They are BCA needles.
