A dyno debate
Posted: Wed Mar 14, 2007 2:47 pm
Hi there, nice new website!!!!
On a different forum there has been some dispute over the claims of a single user. They have an automatic Range Rover Classic with a 4.4 litre Rover V8 (this engine was used in Australia in some British Leyland vehicles).
This is an old school OHV and started life as a 215ci Buick small block. I’m sure some of you are familiar with them.
Not overly powerful, even the last 4.6 EFI units only had 225bhp and ~330lb ft from the factory.
A Range Rover has full time 4wd.
Anyway here’s the problem, they have produced a dyno graph and are claiming PEAK torque @ 1600rpm of 260lb ft to the wheels, they also claim only 50% of the power makes it to the wheels so in essence they are claiming over 500lb ft @ 1600rpm at the flywheel.
So far they will not accept that they may be wrong and that because of the auto the lower section of the torque curve may be inaccurate due to a non lock up converter.
Here is what they have been claiming. I’d appreciate any help or comments you may have as I’m only trying to help them and to discover the truth about their engines performance.
If they are correct and they really do have over 500lb ft @ 1600rpm at the engine could anyone take a stab and explain how?
Cheers.
Here are some of their other comments in the discussion:
Thanks for every ones help
Cheers.
Ok in an auto Range Rover 3rd gear would be 1:1 not 2nd.Here is my Dyno graph. It is real and was done in second gear on a 4WD Dyno. The power is measured at the wheels and therefore there is usually a 30% to 40% power drop from ratings at the flywheel.
So PEAK torque @ only 1600rpm – eh? Normally these V8’s see PEAK torque above 3000rpm.The left edge of the graph is about 1,600 RPM. For those that can do the conversions, as the graph is in KW's and Nm's, at the wheels my car was putting out 260 ft lb of torque at 1600 Rpm. The torque then drops off from there.
Really???No it was at the wheels, so that would be the equivalent of around 400 Fl Lb plus at flywheel. But you have to think about the figures a little more.
No, it has nothing to do with what gear it is in, you will always lose around 40% of your power through the drive train.
It is an old 1970's 4.4 rover V8
Based on the gearing, atmosphere, etc, etc, the peak horsepower figure on the graph is less than half that at the actual flywheel.
I am correct when I have stated that the wheels only generate 50% of the power at the flywheel.
And in a auto, the torque convertor is the equivalent of the flywheel in a manual.
you would need a motor putting out around 500 ft lb torque in a manual to have the equivalent torque at the wheels as my motor and auto. I know that this is a difficult concept for some small brains to comprehend, but it does not change the facts.
Not quite sure how making PEAK at higher rpms proves it makes more power at low rpms? Anyone want to take a stab at it?Tdis have around the same torque at 4,000 RPMs as what they do at 1,800 RPM. Even though the 4.0Ltr V8 develops its peak torque at 3,000 RPM, it still has over 200 Ft Lb at 4,750 RPM. So the V8 has more grunt down low than the Tdi's and can deliver it quicker.
Your problem is that a little knowledge is a bad thing. You read all this stuff and don't understand it, which leads to garbage coming out.
