Repair of Distributor, upper/lower spindle fix suggestion
Posted: Wed Nov 17, 2010 8:17 pm
Having successfully destroying on both my RRC and Vitesse distributor
, by removing the rotor arm.
I have now stripped and reassebled both distributors, the balance weights and springs, etc.
On strip down it was apparent I had damaged the plastic retaining ring that holds the upper part of the distributor inards to the main shaft.(it is located inside the mount for the rotor arm). By pulling the rotor arm up, how else are you suppose to remove them
Anyone know where I could get a replacement? It is like a stepped plastic washer that clips into a groove in the lower shaft.
Was considering filling it with araldite as an alternative if I cant get one, but it might lock the shaft together
Any suggestions would be apprecieted
