Page 1 of 2
Exhaust Manifold Gaskets,
Posted: Sun Mar 11, 2007 8:39 pm
by Coops
Any one know where to get these gaskets from????
Im running a set at the moment, but when i change the heads i want to replace the gaskets, (ones in the picture i have been loaned)
Im going to open up the exhaust ports to match the gaskets also once i have a set.
the only ones i have found so far are these, which i have been told are catalic ones
Posted: Sun Mar 11, 2007 9:11 pm
by r2d2hp
V8Dev sell them Tony
Posted: Sun Mar 11, 2007 9:27 pm
by Coops
the top ones reg???
Posted: Sun Mar 11, 2007 10:29 pm
by r2d2hp
Yes mate, Am sure thats who I purchased mine from.
Posted: Sun Mar 11, 2007 11:25 pm
by katanaman
Looks like RPI does them too, they have a set on fleebay but they include studs and nuts. Probably do gaskets on their own tho. Have you tried Jim? That's who you got your last set from wasn't it?
Posted: Sun Mar 11, 2007 11:29 pm
by Coops
yes i did Marki,
but when i contacted Jim last year he said he could no longer get them
Posted: Mon Mar 12, 2007 10:45 pm
by GreenV8S
The ones you're after look like the twin metal composite ones I get from RPI.
Posted: Mon Mar 12, 2007 10:48 pm
by Coops
you got a picture Pete?
Posted: Tue Mar 13, 2007 6:05 am
by ian.stewart
POP BROWNS do over size single gaskets if anyone is intrested.
Posted: Tue Mar 13, 2007 10:09 am
by IainB
Dont Real Steel also do these, sure Ive seen them / purchased them from there (albeit a LONG time ago!)
Posted: Wed Mar 14, 2007 11:54 pm
by GreenV8S
thev8kid wrote:you got a picture Pete?
"Here's one I prepared earlier".
The port dimensions are 26mm wide 37.5mm high. The ones I've bought previously aren't as chunky as these but the port dimensions are the same. You can't see it from the picture, but they're about 2mm thick and consist of a fibrous matrix with a wire mesh through the middle of it.
Posted: Thu Mar 15, 2007 12:08 am
by Coops
ah yeah seen them before,
im trying to locate the ones that i have in the pictures, as these seem to be the best ones i have used for sealing so far.
Posted: Thu Mar 15, 2007 6:55 am
by Eliot
the topmost ones look very oem. they may be from the later 4.6 engines.
Posted: Thu Mar 15, 2007 6:05 pm
by Coops
Eliot wrote:the topmost ones look very oem. they may be from the later 4.6 engines.
correct,
but nobody seems to stock them now, just the ones like greenv8s posted
Posted: Mon Mar 26, 2007 9:36 pm
by GreenV8S
thev8kid wrote:ah yeah seen them before,
Sorry those aren't what you want.
By chance I came across this advert recently which looks very similar to the ones you asked about:
http://www.clever-trevor.net/part/43/ex ... s0091.html
I haven't seen these in the flesh though.
