Page 1 of 4
My capris latest.
Posted: Sat Mar 10, 2007 5:49 pm
by ihatesissycars
Its newest guise is nearly finished other than a few niggly problems like the ecu turning off when cranking and a small pin hole in my new rad. . . . . . .
Theres some tidying to be done but i don't intend to be driving it until may/june ish so i have plenty of time to smooth of the rough edges.
Me at work!
Posted: Sat Mar 10, 2007 6:13 pm
by Coops
nice one mate,
should this be in the garage section??????
Posted: Sat Mar 10, 2007 6:27 pm
by ihatesissycars
Garage section. . . . . . :roll:
Oopsie!
Posted: Sat Mar 10, 2007 6:32 pm
by Coops
i'll move it mate,
have you had the engine running yet????
Posted: Sat Mar 10, 2007 8:36 pm
by katanaman
yes looking good Gav, what fast idle solenoid is it that your using there?
Posted: Sat Mar 10, 2007 9:38 pm
by Coops
looks like one i was told to try,
it was from a volvo and is a bosch part, not sure if Gavs is the same though,
Posted: Sat Mar 10, 2007 11:05 pm
by ihatesissycars
Its a 3 wire bosch item acquired from a hyundai, megaspurt won't run the 4 wire jobbie normally found with act stuff and tvr stuff etc.
no its not been running with that intake setup but it has ran lots with the itb's so no running in issues luckily.
Posted: Mon Mar 12, 2007 10:31 pm
by scoobyv8
looking good gav, your inspiring me to get on with my project! lol
i'm starting to get better weather for it now too and i'l soon have the funds to get my box and axle i need. then it wont take long to have running.
get some picys of the whole car up! i love capri's
George
Posted: Tue Mar 20, 2007 6:18 pm
by ihatesissycars
I almost had the bugger going again the week before last (i've been egypt between now and then, whic is a poo hole by the way) but the wire i chose to power the ecu drops to 4v when cranking so i need to find another wire to use and also my radiator has acquired a small hole somehow. . . . . .
I probably knocked it or something whilst working on it so i need to get another one now.
I need to also change my cooling system slightly by getting rid of the header tank and swirl pot and fitting my spare top hose filler and putting a pressure cap on that with the overflow going to a catch tank which should be fairly simple to do.
Then thats it!
I need to drag out my 2.0 axle and start stripping that down to swap the lsd into and also make some mounts for the anti tramp bars as well as the bars them selves which will go in place of the anti roll bar.
Then thats it for a long time hopefully!
There is a list of other bits i want to do next though which is firstly and most importantly build the 4.6 engine with tvr heads and then change the rear end for a 6 link setup.
I like the idea of a T5 box too but i'll wait and see on that one.
Posted: Tue Mar 20, 2007 6:22 pm
by ian.stewart
Drops 4v when cranking, where have you taken the power from to supply the ECU, and, Is your battery up to the Job??
Posted: Tue Mar 20, 2007 6:44 pm
by ihatesissycars
The battery is new. It was an unused wire from the ign switch for and accesory that isn't there anymore. I've taken a wire directly from the battery and fed the ecu via that and then turned it over and it worked fine then so its just the wire i've chose to use thats no good.
Posted: Tue Mar 20, 2007 6:58 pm
by Coops
i have 6mm cable going from the battery to a distribution block under the dash that powers just the ecu,
i have a similar thing for the hyfire,
Posted: Tue Mar 20, 2007 7:13 pm
by ian.stewart
I also have a dedicated suplly to the ECU via a connector block, I also run the switched side fron a relay powered from this block, I think this is set by the ign terminal on the back of the ign switch, I will have to confirm by having a peek under the dash, I also run a dedicated earth from the battery for all the ECU functions in the same gauge wire that the feed is.
Ian :D
Posted: Tue Mar 20, 2007 7:32 pm
by Coops
i have an 8mm earth going from the back of the passengers head back to my ecu ONLY,
the hyfire has an 8mm earth going back to the main earth under the bonnet.
like Ian my ignition and ecu has its own seperate power and earths,
Posted: Wed Mar 21, 2007 9:11 pm
by ihatesissycars
I've found a wire from the ign swith i can use now so all is well. I've also ordered my new rad so theres not much to stop me getting the ol girl running agin soon now!
Ps, just bought an X Pack bodykit teee hee hee!
