Rocker covers Vents ??
Posted: Fri Oct 08, 2010 11:14 am
by Chorlton
Where should I vent the 2 vents on top of my rocker covers to?
Just feed them over the side, or into a filter or back into the carb??
Posted: Fri Oct 08, 2010 11:58 am
below the carb into the inlet mnifold, you will need a flame trap in line.
Re: Rocker covers Vents ??
Posted: Fri Oct 08, 2010 7:37 pm
by DEVONMAN
Chorlton wrote:Where should I vent the 2 vents on top of my rocker covers to?
You need to clarify what set up you have. eg. Carb type , injection, and from which model the rocker cover are from.
Regards Denis
Posted: Sun Oct 10, 2010 10:45 am
by Chorlton
Edelbrock 1404.
Covers are SD1
Posted: Sun Oct 10, 2010 12:13 pm
by gelmonkey
I run my breathers into the base plate of my filter and it works just fine.
cheers
P
Posted: Sun Oct 10, 2010 12:32 pm
by DEVONMAN
gelmonkey wrote:I run my breathers into the base plate of my filter and it works just fine.
cheers
P
I agree that this is the simplest way to achieve passive crankshaft ventilation. For positive ventilation, you would need to fit a PCV valve and connect one of the rocker covers to the inlet manifold and the second rocker cover should then have a small filter fitted.
It seems to me that the rocker covers in question are the P5 or P6 type as the SD1 covers I have don't have two breather connections.
Regards Denis
